Sorry about the 21 questions,but why is that?
CellC brought it down to 900MHz and its 21mbps and it was slower at higher frequencies,but the lower you get the less badwidth is available?
What frequency does a TV work on,like SABC
Happy to answer:
21.1 Mbps is HSDPA cat. 14 standard. Since it's a fixed standard with fixed constellation mapping, source coding, modulation etc. It has a fixed, predictable bandwidth. Clearly, Cell-C owns enough at 900 MHz to shift their transceivers' central freq. there. The reason you most likely experienced slower speeds at higher frequency is that you had worse attenuation since the RF signals suffer more loss the higher the frequency they are (most basic example, and too idealistic for a practical model, is free space path loss). This results in lowered signal-to-noise ratio (SNR) which means that the bit-error rate (BER) becomes so high that, and this is how transceivers are designed today [Adaptive coding & Modulation], it switches to a smaller constellation so that your BER is reduced. This means less errors but also means reduced speed (since 1 symbol is now say 5 bits instead of 6).
Now, this is great in that if we move comms down the frequency range, we get better rates, sure. The problem is, you have other people who have licensed spectrum, so you don't have everything to yourself, i.e. you have fixed bandwidth. If you have been given x amount of bandwidth by ICASA at around 900 and hsdpa cat. 14 only requires <x, perfect, move it. The problem becomes when you want higher data rates. There's a practical difficulty in implementing transceivers (called the Q-Factor) in that the filters' bandwidth are a percentage of their centre frequency. i.e. the higher you go, the larger the pass-band of your filter. This is why ITU-T and others agree to place lower rate (smaller signal bandwidth) communications lower down the frequency range so that we don't have narrow bandwidth signals with large, un-used bands up top. All this in layman's terms is the compromise of longer range vs higher rates.
Hence why if there was (and there isnt) cellular hardware at 300 MHz, the bandwidth it would get would probably only be sufficient for GPRS.
With regards to TV, the lower end of UHF is at around 900 MHz. SABC is VHF if I remember correctly, but e-TV is UHF.
P.S. excuse all bad typing, frozen fingers
