D Link DSL-2640u firmware update 29-11-2010
Barge
http://ftp.dlink.ru/pub/ADSL/DSL-2640U_BRU_C/Firmware/RU_1.25/
Mine's the hardware model C1, I can't say if that's the case for all South African models, but that's the one that's been updated. if you think you have one of the other dsl2640u models, browse through the ftp folders to http://ftp.dlink.ru/pub/ADSL/ to find your version, for example:
DSL-2640U
DSL-2640U_BRU_C
DSL-2640U_BRU_C2
DSL-2640U_BRU_CB
DSL-2640U_BRU_D
Googles translation of the Russian release notes
###### RELEASE NOTE ###############
Device model: DSL-2640U
Compatibility with hardware revisions: C1
Type the ADSL line: Annex A
Firmware Version: RU_1.25
Release Date: November 29, 2010
File Name: DSL-2640U_BRU_C1_RU_1.25_20101129.zip
File Size: 3.4 MB
Hash sum md5: b780decd978f0f7ec58cedc0a78e9594
Changes:
1. Correction of errors PPTP-client to connect to a remote VPN-server over PPPoE interface, and MER.
2. Correction of errors when trying to use PPTP-client as the default gateway.
3. Removed lock SSDP packets from a wireless interface.
Firmware Version: RU_1.24
Release Date: June 7, 2010
File Name: DSL-2640U_BRU_C1_RU_1.24_20100607.zip
File Size: 3.5 MB
Hash sum md5: 75ebddfa4a8fb32a60ef4677aafa5d13
Changes:
1. Fix for IPSec (DSL-2600U, DSL-2640U).
2. All services modem (ARP, DHCP, ICMP, HTTP, FTP, TELNET) in the direction of the provider network is blocked, if the modem is running at Bridging.
3. The web interface adds the ability to create static routes without the IP-address of the gateway.
4. Blocked access to the device for Telnet using the account "user".
Firmware Version: RU_1.23
Release Date: 03 feralya, 2010
File Name: DSL-2640U_BRU_C1_RU_1.23_20100203.zip
File Size: 3.5 MB
Hash sum md5: 92b6043f4d3b093c2fc0d8a94b93abbe
Changes:
1. Added ability to disable the client's TR-069 through a Web interface.
Firmware Version: RU_1.22
Release Date: November 4, 2009
File Name: DSL-2640U_BRU_C1_RU_1.22_20091104.zip
File Size: 3.4 MB
Hash sum md5: 7b27d6e6d73776980f8440174d931244
Changes:
1. Changed the delay between sending the query when trying to install PPPoE-connection:
Sending PADI -> pause 2 sec. -> Sending PADI -> Pause 4 sec. -> Sending PADI -> pause 8 seconds. -> Sending PADI -> pause 16 seconds. -> Sending PADI -> pause 2 sec. -> Sending PADI -> Pause 4 sec. -> Etc.
After every 17 PADI-query router sends a PADT.
2. Added ability to specify the address of PPTP-server host name.
3. Options: "NAT" and "Firewall" enabled by default when creating a MER or IPoA connection to WAN-interface.
4. On the page "Device Info" added information on the release date (Release Date).
5. Fixed arbitrary changes to the MAC-address 02:10:18:10:10:01
6. Added Keep-Alive for PPTP-client
7. Automatically update the page and return to the home page after the firmware update procedure
Firmware Version: RU_1.21
Release Date: July 30, 2009
File Name: DSL-2640U_BRU_C1_RU_1.21_20090730.zip
File Size: 3.4 MB
Hash sum md5: de233998866b680f9354b313ec3a413f
Changes:
1. Updated ADSL PHY driver.
2. Security Update Web GUI.
3. Change the spacing between sending packets when you try to PADI PPPoE-connection.
4. Fixed problem that resulted in a router does not send PADR packet in cases where a network of 10 or more PPPoE-server.
Firmware Version: RU_1.20
Release Date: May 6, 2009
File Name: DSL-2640U_BRU_C1_RU_1.20_20090506.zip
File Size: 3.4 MB
Hash sum md5: 5a62fc749d18bed2dcdd38fc3964f573
Changes:
1. If you use PPPoA-connection does not open some sites (corrected).
2. Multicast traffic is now blocked by a wireless interface
3. On Page Device Info> WAN added information on the status of PPTP-connection (PPTP Info).
4. On page Advanced Setup> PPTP option added Always On. If this option is enabled, in case of a break PPTP-connection, the router will restore it.
5. For DSL-2600U/BRU/C Fixed error when using WEP-encryption.
Firmware Version: RU_1.12
Release Date: January 20, 2009
File Name: DSL-2640U_BRU_C1_RU_1.12_20090120.zip
File Size: 3.4 MB
Hash sum md5: fa0c8706f2c4a283ef7520633fabf069
Changes:
1. dhcpc updated to version 0.9.8
2. The algorithm works with SYN packets in networks of providers.
3. Fixed bug with inability to activate the "Bridge PPPoE Frames Between WAN and Local Ports" in the WEB interface.
4. Added support for SNMP and TR-069.
5. Added option "Retry PPP password on authentication error" in the settings PPPoA connection.
6. Fixed bug DHCP connection, does not allow PPP and MER PVC in parallel (for example, is important for service Mediazone UTC).
Firmware Version: RU_1.10
Release Date: November 25, 2008
File Name: DSL-2640U_BRU_C1_RU_1.10_20081125.zip
File Size: 3.4 MB
Hash sum md5: fcca9738fb0a6b3e9e2bc84f6ac6cbbf
Factory firmware.
so tell me... If I'm already running RU_2.01 is it really necessary for me to update? and could anyone please tell me why this router isn't more user friendly, I thought every dlink router had a quick setup guide in it :(
you could have looked it up yourself, but here's a google translation of the release notes at:
http://ftp.dlink.ru/pub/ADSL/DSL-2640U_BRU_C2/Firmware/
see if any of the updates address any issues you may have.
################################################## ###### RELEASE NOTE ########################################## ##############
Compatibility with hardware revisions: C2
Firmware Version: RU_2.05
File Name: DSL-2640U_BRU_C2_RU_2.05_20101129.zip
File Size: 3.3 MB
Hash sum md5: 9e2ca5035051f2bfbf96be65a35223fd
Changes:
1. Removed lock SSDP packets from a wireless interface.
Firmware Version: RU_2.04
Release Date: October 26, 2010
File Name: DSL-2640U_BRU_C2_RU_2.04_20101026.zip
File Size: 3.3 MB
Hash sum md5: ccda7f37e05b6ad66697157f454a08a1
Changes:
Firmware Version: RU_2.03
Release Date: August 4, 2010
File Name: DSL-2640U_BRU_C2_RU_2.03_20100804.zip
File Size: 3.3 MB
Hash sum md5: 03ea35a29e93efe42ba0b91fbcf65cde
Changes:
1. Correction of errors in the function of PPTP-client.
Firmware Version: RU_2.02
Release Date: April 21, 2010
File Name: DSL-2640U_BRU_C2_RU_2.02_20100421.zip
File Size: 3.3 MB
Hash sum md5: 297c0dfe6ac5bf038e75f978d3a2338b
Changes:
1. Fix for IPSec.
2. The web interface adds the ability to create static routes without the IP-address of the gateway.
3. Blocked access to the device for Telnet using the account "user".
Firmware Version: RU_2.01
Release Date: November 7, 2009
File Name: DSL-2640U_BRU_C2_RU_2.01_20091107.zip
File Size: 3.3 MB
Hash sum md5: 26d40724957a7e895971a34ebcfd9c2c
Changes:
1. Fixed problem with disabling SNMP.
2. Automatically update the page and return to the home page after the firmware update procedure.
3. Fixed arbitrary changes to the MAC-address 02:10:18:10:10:01.
Firmware Version: RU_2.00
Release Date: August 10, 2009
File Name: DSL-2640U_BRU_C2_RU_2.00_20090810.zip
File Size: 3.2 MB
Hash sum md5: cb593f1133f6d5dc456e6c851276f46f
Factory firmware.
another google translated document
How to choose the firmware for the DSL
How to choose the firmware for the DSL-2640U?
Before the firmware update procedure is necessary to clarify the hardware revision (H / W) of your device.
order to correctly identify the hardware revision of the modem look at the label on the underside of the device. Find it on the line that starts at "H / W Ver .:". Letters and digits indicate the hardware revision.
Examples:
http://dlink.ru/up/uploads_img/5/xDSL/2640_b2.jpg
http://dlink.ru/up/uploads_img/5/xDSL/2640_d1.jpg
http://dlink.ru/up/uploads_img/5/xDSL/2640_c1.jpg
Hardware revision B2
hardware revision D1
hardware revision C1
Downloading firmware for DSL-2640U
All firmware available on the ftp://ftp.dlink.ru/pub/ADSL/ FTP-server Company D-Link.
Attention! Set the firmware version, not related to your device, can lead to unusable.
for revision: A1 , B1, B2
Recommended Firmware:
ftp://ftp.dlink.ru/pub/ADSL/DSL-2640U/Firmware/V.3-06-04-3H00/RU_DSL-2640U_306043H00.zip
3 -06-04-3H00
http://dlink.ru/up/uploads_media/firmware_upgrade_u_series.pdf
how to update the firmware
ftp://ftp.dlink.ru/pub/ADSL/DSL-2640U/Firmware/ReleaseNotes.txt
for revision: D1
ftp://ftp.dlink.ru/pub/ADSL/DSL-2640U_BRU_D/Firmware/RU_1.12/DSL-2640U_BRU_D_RU_1.12_08282009.zip
RU_1.12
http://dlink.ru/ru/faq/160/766.html
http://forum.dlink.ru/viewtopic.php?t=68843
list of changes
for revision: C1
ftp://ftp.dlink.ru/pub/ADSL/DSL-2640U_BRU_C/Firmware/RU_1.22/DSL-2640U_BRU_C_RU_1.22_20090902.zip
RU_1.22
http://webdev.dlink.ru/fw/DSL-2640U/V.3-06-04-3H00/RU_DSL-2640U_306043H00.zip
http://dlink.ru/ru/faq/164/857.html
http://forum.dlink.ru/viewtopic.php?t=72399
list of changes
Hi
EXTRA VIRGIN NOOB HERE
Please advise as to why my D-Link is almost dead - so slow it disconnets everything - dne no updates as I haven't a clue - no problems with ADSL or Bandwith.
Please assist.
difficult to help with li
mited information. You may get a better response from the forum if you post a new thread with a subject such as "d-link router disconnects all the time" as this thread is more about a specific model and your issues could be more generlised - e.g. noise on the line.
Give details such as model number, is it wireless, is it the wireless part that disconnects all the time or is it connected by network cable. some routers have an auto-disconnect feature for when the connection is idle. good luck.
Just a friendly warning...do not upload firmware through Google Chrome - I got a fatal error that way. Go the safe route and use IE
hello,
can i update my firmware (dsl -2640U... H/W: C2....F/W:ME_2.01)from "C2/ME_2.01" to "C2/RU_2.05" ? is it possible??!! (F/W is not the same!)
As long as the H/W version is the same, you should be fine.
Is there any particular reason why you'd want to update the firmware?
I had to update my DSL-2500U's firmware, because the Dynamic DNS option was missing, amongst other things...
I had no idea it was so dangerous to update the Dlink 2640U's firmware.
I did update to 29-11-2010 in December with Opera(And made sure the H/W version was the same though).
Knowing this now, i don't think it was worth the risk...
hello i have a big problem with dsl 2640u
i fell that the router dont work very well
i had a several pb with DNS and DHCP to fix those i installed the last update of firmware C1 version 1.25 after the installation the router reboot permanentely with duration of 3s
my question is how can i repair may router
configuration of my router
model no dsl 2640U
h/w c1
can't tell you how to repair your router other than to press reset oe unplug it for 10 minutes.
In my experience the dns and dhcp problems are not always the router's problem. I just had a similar issue with a Mega100 router where an XP pc with wireless USB dongle could not access the internet. Instead of playing with the router or its firmware, I changed the primary DNS address on that PC's connection to be the same as the router's gateway address (the address you type in your browser when you want to login to the router setup). I left the secondary DNS blank. No problems after that.
