3x1GB or 2x2GB? - For i7
Just get 3x2GB and save yourself the trouble of upgrading ram for the next 3-5 years.
2x2gb. The difference between dual and triple channel are basically unnoticeable.
OCZ PC3-12800 DDR3 6GB Intel®i7 Edition Low-Voltage Triple Channel 3x2GB Kit - Profile 1: 1600MHz CL 8-8-8-24 1.65 Volts, Profile 2: 1800MHz 9-9-9-28 1.65 Volts
read this
which i7 are you referring to? :confused:
remember that you get the "new" i7 which is optimized with a dual memory controller on board.. this is the socket 1156 (i7 860 & i7 870)
the older i7 is optimized with a tripple memory controller on board... this is the socket 1366 (i7 920 & i7 950 etc etc)
I would imagine this would make a difference
thoughts?
I dont know much on the socket 1156 ddr3 memory situation, but if you ARE referring to the socket 1366 then do yourself a favour and read this.
yes its, long but you will learn a crap load... i did! insane article! :)
http://www.anandtech.com/memory/showdoc.aspx?i=3589
Just curios, but isnt the Core I7 LGA1366 Triple channel DDR3 therefor 3 modules would run better than 2?
However the newer Core I7 LGA1156 done away with one chanel and is now dual channel DDR3, therefor 2 modules would be better.
So it depends on your socket. If I am correct
I was going to do an upgrade every 6 months :D then I found out I'm better off spend the money on something else.
Like what :/
Ok, so i've decided if i can't get the OCZ tri channel kit i'm after i'm just going to get 2x2GB Corsair. Doesn't seem to be much of an improvement from dual to tri channel
