4pin 12v CPU rail extender.
nihilist
'sup guys.
I'm prob buying that neato Antec Three Hundred case it seems, as the current case just don't do!
I have an oldish Antec 380w earthwatts PSU, but I fear the 4pin yellow/black 12v connector that powers the CPU won't reach, even my Antec P180 and the Antec PSU that they reccomended struggled to reach.
The PSU on the Antec 300 case is at the bottom, hence the length being an issue.
I can hack off a plug from another old PSU and extend the wires but I don't really want to void the warranty of the PSU.
So looking for a 'legit' way of extending the wires.
Sybaritic don't seem to stock anything like that.. any ideas?
This sort of thing?
I have seen one locally (was at Esquire) and eBay that connects to a standard molex plug, but if you want one similar to the one in the link, then you may have to get one made up (or make it yourself from an old PSU and old motherboard plug), unless you can find a supplier in SA.
Try this on eBay or this one -- there are many eastern based places that make these types of cable to... :)
