nicroets
Two questions:
I assume the SIM must be on the SmartBroadband Wireless Prepaid tariff ?
If I buy it today, when will it expire ?
Two questions:
You'll see "Refreshing SIM Data" dozens of times per day after which you won't have any internet access (for a few minutes). That's the only reason why I'm back on the FreeMe bundles.how good are those LTE deals if i want to use it on my phone?
I understand i wont be able to roam
Are you sure about sharing? A couple of weeks ago I bought a 5GB bundle with the intention of splitting it with my two girls only to find that the LTE bundle did not show up on the data transfer screen.I use this bundle for my routers. Plural. You can transfer part of the bundle to another Smart Broadband Wireless Prepaid sim.
Also it's prepaid. So if use less one month, you can buy smaller bundles.
how does it work on a mobile phone?These month to month deals are nice. The 10+10 gb from axxess for R99 is very decent.
You can transfer up to 1GB data per day to any other Telkom simcard including prepaid simcards so you can have it in your mifi or in your fixed lte router at home and then transfer some data to your phone simcard.
do you also get "Refreshing SIM Data " like the orge?
Yeah. The biggest problem for me is the fact that it works exclusively on Telkom Mobile's LTE bands, if you don't have LTE, it doesn't work and you get the Refreshing SIM Data message.Yeah it depends on phone and location. It doesn't happen a lot in fact might get it once every 2 or 3 days and you don't always notice it better if you switch Telkom -R off
In my bedroom, LTE is practically non-existent. Just last night, we had issues with our fibre line and my wife couldn't use her LTE data at all
You see that's where you have it wrong and which Telkom Mobile does not make clear when they advertise these products.But it should work on Telkom 3G/2G too.
From here (this is for the uncapped bundle, but the same is true for the capped oens)
"2G/3G failover will not be supported as the SmartBroadband Uncapped Wireless service is a fixed wireless service which must be used in a fixed location. The SmartBroadband Uncapped Wireless subscriber will not be able to roam on Telkom or MTN’s 2G/3G network and shall be limited to Telkom’s fixed wireless LTE network. ".
The above reduces the useasbility of the bundle considereably should you want to use it in your phone.
All I can tell you is it does not work for me or any of my family members when there isn't any LTE coverageOkay a few things.
I have the original R599 now R529 uncapped simcard. Works fine on Telkom 3G snd 2G.
I have a 20gb+20gb Telkom capped simcard from Afrihost that came with a Huawei B525 and works fine on Telkom 3G and 2G.
I have a prepaid simcard on smartbroadband wireless prepaid price plan. Loaded the 5gb+5gb bundle and blocked Telkom -R on *180# and now use it in a very old 2G/3G Huawei Mifi and it's working fine.
So all the situations I tested it works.
Okay a few things.
