64 bit dvd, 32 bit key
steveninspokane
Hey i bought a dell a year ago, it came with vista 32, i just bought a new comp, and bought vista 64, im going to put 64 on the new comp, but im wondering can i use the 64 dvd and install it on the old Dell using the 32 bit key that dell gave me on the dell, and using the 64bit key for the new comp with no problems?
thanks
Some sources say it will...
So you might be in luck...
