Yip, it can be due to insufficient and/or noisy power.
Even if the voltages are correct does not mean the PSU is fine. You can have the correct voltages but it might not be able to deliver the required current under load.
If you are short of cash, you could ask a friend to repair it, but I wouldn't try to repair this one, as PSU has probably design problem, it shouldn't fail this way. I woudn't trust it anymore (nor any other of the same brand).Ok, so Matrix warehouse tested my whole rig, PSU,Mobo are blown because of the tripping of the sub station next door to us, now what do I do?
Tell them truth, technician will check if mobo is working and look for physical damages which voids warranty and doesn't care what customer says.I bought the Xigmatek Vector S 850W 80+ silver, but im wondering if I can RMA the Mobo even if the product fault wasn't cause by the product its self.
How do you know it failed on the surge, or other reason?
So I felt like formatting my C drive today, i went into my UEFI Bios and i dragged the installation disk to the front of the boot queue, rebooted, and now the screen wont display anything and my keyboard wont light up. What could of happened?
I removed the GPU, still no signal from onboard GPU,USB and ps2 ports are dead. I think i may have bricked this board...
What else could it be?
Power station blew -> blew the PSU which blew the mobo.
