I was wondering how the Drifta works.
Do you insert a smartcard into it?
If not, cant anybody just go buy one and then use it to watch DSTV?
Can you watch TV on the Drifta at the same time as watching DSTV on your normal home PVR or will suing the one disable the other for the time the one is being used?
If this can be done anybody can just register a Drifta on a friend's, who has DSTV, name and then use it is'nt it?
Or am I missing something somewhere?
