will this panel work with my setup?I don't think 1 x 250W is enough to start the MPPT. You probably need something like a 400W, but I would just go big like a 650W.
View attachment 1461353View attachment 1461357View attachment 1461359
Don't know, geewiz don't show any specs. Is it more than 30V?
Attached the specs.Don't know, geewiz don't show any specs. Is it more than 30V?
Trying to go the cheapest route, I just need a panel to maintain my current load of 100w -150wPoly.... Hmm
Get 2x330's
There's hardly anything in it at the end of the day, a few percent, so I agree, just get the cheapest.Poly.... Hmm
Get 2x330's
But I like wingnut771's one better.
Hi, hoping you can give some advice. I'm trying to help a pensioner who doesn't have thousand to spend on nice hybrid models etc, so looking for something basic that she can run two 180W tv's during load shedding and lights at night. They have alot of electricity issues and some times it goes days before repairs, so charging battery via ac is a bit of a problem.For a quick and dirty short-term solution that wouldn't break the bank, I would just install one 420W solar panel and a Victron 75/15 charge controller, as here. According to the Victron charge controller's specs, it can handle up to 440W at 24V.
That means during the day, your batteries will last much longer if you've got load shedding. The batteries will also wear less since you'll probably not drain them as much during daytime load shedding.
If you don't have load shedding, you'll have the added benefit of the batteries charging faster since they will be charged by the inverter as well as the solar panel.<- This is not true, as pointed out by wingnut771
The solar panel will cost about ~R3000 and the charge controller R2000, R500 for cables the whole affair will set you back about R5500. And it is super easy to set up, just connect the batteries and solar panel to the charge controller, and it'll do its thing. The charge controller I linked has the ability to connect to your phone via Bluetooth that way you could configure it for your lithium batteries.
If your base load is about 400W (that's the internet, a TV and a few lights), you'll basically use no battery power during daytime load shedding and your batteries will stay full for nighttime load shedding.
I assume there is no charger with this inverter, so there is nothing to worry about. Connect inverter to battery, connect solar controller to battery, job done.Hi, hoping you can give some advice. I'm trying to help a pensioner who doesn't have thousand to spend on nice hybrid models etc, so looking for something basic that she can run two 180W tv's during load shedding and lights at night. They have alot of electricity issues and some times it goes days before repairs, so charging battery via ac is a bit of a problem.
Let me tell you what I want to do and you guys can tell me yes or no or provide addition comments. She currently has a Lalela, but it is not doing the job or handling the load battery wise and you can't extend the batteries to more in parralel or even add solar panels.
I have lying around a Aerbes Modified Inverter (1500W) with 70% capacity. View attachment 1468257
I want to set this up for her to use this inverter to run two tvs and 5 lead lights. I was thinking of adding the following.... 2 x 380W Mono Solar panels, 30Amp Solar Charge Controller, 2 x 200AH Solar Gel Batteries OR 1 x 200AH Lithium Batteries. Was hoping to have extra solar panels to run tv from solar during the day and not batteries, but I'm not sure how to do that with this inverter.
Need some help here, please.
Yes, no charger on inverter. Hence the solar Charge Controller, however not sure if the 30A controller will be sufficient for the 2 x 200AH Solar Gel Batteries OR 1 x 200AH Lithium Batteries. And I'm also not sure if the 2 X 380W solar Panels will be sufficient to charge 2 x 200AH Solar Gel Batteries OR 1 x 200AH Lithium Batteries.I assume there is no charger with this inverter, so there is nothing to worry about. Connect inverter to battery, connect solar controller to battery, job done.
Should be. How many watts is the controller?Yes, no charger on inverter. Hence the solar Charge Controller, however not sure if the 30A controller will be sufficient for the 2 x 200AH Solar Gel Batteries OR 1 x 200AH Lithium Batteries.
That's why I said to start with a killawatt.I have to ask, what is the pensioner doing with two TVs during loadshedding? Is someone sponging of her? Nothing much wrong with it but maybe they can sponsor some cash towards the solution? 180W is a lot of watts on a backup battery, but 360W even more so.
Take the Lalela and use it, at least it still has a charger, unlike the other one, it's a Mecer or Ellies clone last time I checked, you are going to have a hard time haversting enough solar with cheap PWM charge controller, so I don't think it will work out well on solar alone.
just check first .those aerbes are modified sine wave .led lights and lots of lectronics dont like them .leds flicker .some of the cheap inverters draw 1amp from batteries just idling ive tested some at 9 amps .if you buy a pure sine wave brick inverter like the aerbes the wattage output will be around 30 percent of whats claimed .we use them in vehicles .they work well on small loads .Hi, hoping you can give some advice. I'm trying to help a pensioner who doesn't have thousand to spend on nice hybrid models etc, so looking for something basic that she can run two 180W tv's during load shedding and lights at night. They have alot of electricity issues and some times it goes days before repairs, so charging battery via ac is a bit of a problem.
I spoke to the Lalela technical department regarding adding an additional battery onto the inverter, they said it is not adviceable to do so and the current battery set up is just not cutting it. Hence was thinking if it can charge via solar that would be great and a bigger battery. There is only one income in her house and that is hers.I have to ask, what is the pensioner doing with two TVs during loadshedding? Is someone sponging of her? Nothing much wrong with it but maybe they can sponsor some cash towards the solution? 180W is a lot of watts on a backup battery, but 360W even more so.
