ADSL Router log-in problem
rek123
I have a beige adsl router with 4 ethernet ports and 1 usb port. No manufacturer name, but on the router is printed: ADSL Router. I have reset the router. If i type 10.0.0.2 i get the login screen. I can also ping and get the 4 responses. But I can not log-in. I have tried all the combinations I could get on this site, eg admin, root, etc, but can not get logged in to set it up. Any suggestions? Must the router be connected to my adsl line when I log-in?
Have you tried:
username=admin, blank password
username=admin, password=admin
username=admin, password=password
Those are the 3 most common combinations of passwords that usually work.
Yep, just tried again, not working. After 3rd attempt I get the Access denied screen and have to refresh.
try
username: root
password: blank
username: root
password: root
username: root
password: admin
Tried them all. That is what is so frustrating and the modem doesn't have a make anywhere printed on it.
post some pics.. maybe someone can identify the make and model.
As you can see, I am a junior member :o . How do I upload a photo
if this is an old telkom router try the username "admin" and the password "conexant". it sounds like you have one of the old marconi routers
You can upload a photo to like zoopy.com (hosted locally) or to imageshack (hosted in US)
admin
administrator
administrator
admin
admin
admin
administrator
administrator
admin
password
administrator
password
8/10 times for routers
Fantastic!!! It worked. Thanks to all who helped. The best site that I came a cross....
I want to get into the adsl router to but don't know the username and password. The guy who set it up died.
What now? Should I try some of the above even though he used customised U&P?
Telkom Mega 105WR
Telkom Mega 105WR
Factory reset + default login U&P
