HI
For the past 4 months I have been experienceing continuous disconnects with my ADSL especialy during the evenings. I have loged multiple faults to Telkom and all the techs they have sent cannot fix it. Basicaly every evening my internet disconnects ever 10 - 20 minutes, My SNR(downstream) values start strong at around 22+dB and slowly decrease till they reach 6dB - 0dB and sometimes even -7dB. It takes a few seconds for the SNR to go back to normal by itself or a router restart fixes it but then it just repeats the process. I am currently on a 4Mb line and my area supports up to 10Mb, I am also 2.6Km from the exchange.
I have test almost everything:
Tried 3 different routers
Changed all my cables
changed all the splitters and filters
Removed all the telephones on the line
Tried it on all 3 pc's and consoles
Test using only wireless devices
Turned off electrical appliances in house hold such as gysers heaters microwaves TV etc.
Tried different plug points
Used a UPS system on router
Used USB router
Ajusted internal setting on router
Used 4 different ISP accounts
Got my line speed reducesd from 4Mb all the way to 384kb line (3Mb, 2Mb, 1Mb, 512kb all tested and same problem)
Telkom has sent out techs and even a ASDL specialist and they still cant find the problem. They have done the following
Changed the cables to my property
Changed my ports and equipment at the DSLAM
Changed my ports and equipment at the exchange
Monitored for noise on my line (they say theres none)
They checked for voltage leaks on my property
They checked whether my property had enough power and correct voltage to all my plug points in my house
They checked all the cables from the exchange to my premises
They monitored for electrical interferance on the line
The techs say that if there was a problem with my line or if there was noise and interference I would be able to hear in on my telephone but my phone is clear all the time
They said that no one could be leeching of my line because its runing on a single closed circuit
Telkom says that its not due to traffic because the traffic only starts to build up at around 8pm in my area and my problem starts at around 3pm
After all the trial and error testing the problem still persists I have had ADSL for 5 years and this only started 4 months ago
If anyone has and further ideas or perhaps knows what I can do to fix this I would greatly apreciate it.
Used USB router
