Advice for renewing contract
sajunky
JHB
Current: Vodacom 240min, some data - never used (paid R435p/m with Nokia C3).
Prefered:
- stay with Vodacom
- no device
- no data usage planned
I suggested move to prepaid 79c/pm per second billing. With 240 minutes usage the monthly cost is less than R190 (due to per second billing), estimated R100-R150. Any better deals?
Cant see anything better than that, esp since you dont want a contract or a new device. I takr it you will continue with your own device? Vodacom im sure has a Use your own sort of plan, but that would mean going on a cheapish contracf
Thanks. but "use your own device" contract means much higher tarrif.
Bottom of line, if you want contract and cheap calls, it can't be Vodacom.
