Hi.
We've just installed an extensive (CAT5e + Fibre + Wireless) network for one of our clients. The wireless part consists of 6 of these guys: EnGenius M36 Mesh Ceiling AP, MSSID, WDS, VLAN Tagging, PoE, 1 LAN
They are already set up and working, connected directly to the wired network via ethernet, and powered via POE. They are connected an AP mode, but I'm pretty sure there is more we should do to get a better wireless network.
The network (Wired + Wireless) currently supports about 40 PCs, laptops and servers, as well as a number of Smartphones that connect to the wireless network. Ideally, we would like a setup that is secure, but whose security protocols (WPA, WPA2, etc) support the widest number of devices, at the highest possible speed. We have already ruled out use of WEP (for obvious reasons).
Some questions:
Any help, advice/criticism will be appreaciated.
Thanks.
Some questions:
- How should we set up the channels on each WAP? The 6 WAPs cover most of the working area at our clients premises. Should we setup each WAP on a seperate channel, and if so, how do we determine which channel to use for each WAP?
- The WAPs are not setup in mesh mode, but in AP mode. What is mesh mode? Do I need it? Is it a good idea to set it up? Each WAP is fed by a Cat5/ethernet lead.
- How do I make it possible for laptops & smartphones to roam throughout the premises without losing connection (assuming they are in an areas covered by one of the WAPs), i.e. the connection gets handed over from 1 WAP to another seamlessly (this is especially important for VoIP calls).
- What software tools do you use to help diagnose problems on a wireless network? Are there any good free ones available?
Thanks.
