The_Unbeliever
Some of you who've got your dongles probably wondered how to access the "advanced" settings on these.
It is very simple, and quite easy too.
Simply connect it up to any Windows PC (XP and above) via USB, not via wireless.
You will then need to install a small application.
Once done, you will have an Afrihost icon on your desktop. Double-click on this to open the mifi advanced settings page.
This will open in your default web browser.
A few screenshots :
This is the home page which you'll get when starting it up.
It is quite simple, most of you should have no issues doing what you want.
The interesting part(s) can be found under Security, where you're able to set up port forwarding and virtual servers. Should be interesting, having a web server at all times with you
If you want to change your device's DHCP settings, that can also be done :
Go to WLAN - DHCP, and chop and change to your heart's contents.
If you're really serious about security, you can set up MAC address filtering :
There's tons of other settings and stuff so you can fine tune it to what you want.
Enjoy!
A few screenshots :
Enjoy!
