AirDisk Pro - Wireless flash drive
Good reader seems to have similar functionality (and a whole lot more).
Yeah, It can. Quite right, forgot it could. Damn, it's a hot piece of software!!! Reckon it will be 15-20% better on Retina...
Ok so I downloaded AirDisk Pro the other day and I have to say it's a very good file transfer app that has one feature missing from Goodreader and that is the ability to drag and drop via a web browser. Definitely worth the 99¢, even if you do have Goodreader.
Agreed, Goodreader is such a competent piece of software though. Wonder why the developers haven't incorporated the drag and drop file transfer system? But more importantly do they intend implementing one in the future?
I didn't realise until just now when I tried it that goodreader had a html web interface at all. :o
So how you been syncing? Cable and iTunes?
On OsX I just have Goodreader set up as a server so it opens up as finder window. Then I just drag and drop from there.
Well that's very convenient!!
It does work well but I was thinking now if I had to explain to a Windows user what to do I wouldn't have a clue where to start so an easy to use web interface is handy.
