erduplessis
- Mar 26, 2018
Hi guys,
Here goes another thread about this topic...please bear with me...
I have a Asus RT-AC5300 installed. I bought it because the family likes streaming lots of stuff at the same time, and I figured this will do the trick. 50/50 fibre line installed.
I don't get good signal in the garden, where I like to stream music on my outdoor speakers (the neighbours haven't complained yet...).
SO, I have hooked up my old Asus RT-N12HP (configured as an AP) to the RT-AC5300 (the router) via Cat6 cable, about 20m long. All is connected, and everybody is seeing each other fine. I have two different SSID's...but the speed I'm getting on the AP is BAD. Speedtest is telling me 1.5Mbps. If I connect to the wifi of the router...speed rocks. I'm connecting both on the 2.4GHz frequency, and I've separated the channels (AP running on channel 10, router running on channel 1). There is a lot on congestion in the 2.4GHz range around me, but I have tried changing channels, to no avail. Even if I swop them around (put router on channel 10 and AP on channel 1), the router consistently gives me full speed network, and the AP gives slow network.
The router is configured to assign manual IP address to the AP. I'm not sure what other info to give.
Why would the speed through the AP be so much slower?
The router software claims that the LAN connection speed to the AP is 100Mbps, so it is not running a Gigabit connection, but it still doesn't explain the 1.5Mbps throughput I'm getting.
I'm using my home made network cable. Figuring that might be the problem, I've tried a shop bought 1m long cable, but that hasn't helped. There must be a setting somewhere in either the router or the AP that is causing trouble. Does anybody have an idea??
Etienne
Etienne
