Antenna Connectors?
elf_lord_ZC5
Bloemfontein
I need to connect 2x antenna's to one of these http://www.miro.co.za/detail.aspx?pid=1158&p=&sp=&spp=
And I have 2x Trendnet TEW-A17508 external antenna's which I want to connect to the above radio card.
The blurb on the antenna box says "will work with any brand of device with Reverse SMA Male connector"
These antenna's will connect to my ADSL wireless router or the external antenna connector on PCI wireless cards.
My surmise is that the antenna's have Reverse Polarity Male connectors, and I need to purchase UF.L to Reverse Polarity Female connector pigtails.
I want to know if I am correct.
Many thanks
@protz
Need one like that with the pin in the middle. Buying the card from Miro as the seem to be the only ones to stock a miniPCI-E card, so cheaper to buy pigtails from them as well, pay once for courier fees.
