Aopen Xcube power supply
Peon
In my burrow
Hi Guys
Where can I source a power supply for a Xcube. They classified as a SFF power supply but to the best of my searching I cant find a compatible one.
Rectron does not have any and doesnt know where to get one either.
Any ideas?
Peon.
PS: For an optimetrist and the small box is just amazing and fabulous etc,etc,etc.
Perhaps it may be quicker just to transplant the innards into another sff / mini-itx case with PSU, if it is not too proprietary... ?
Just remove the internals from the Aopen and plonk them into something like this;
http://www.wootware.co.za/cfi-8989-...-power-supply-compact-cube-size-mini-itx.html
Quick Overview CFi 8989 Black, with Internal 150W SFX Power Supply, Compact Cube Size (30.3x20x16.6cm), ABS Aluminium with Hairline Finish, 2x...
R 480.00 Incl. VAT
or similar...
EDIT: or this...
http://www.wootware.co.za/coolermas...dvanced-usb-3-0-mini-itx-desktop-chassis.html
Coolermaster RC-120A-KKN1 Elite 120 Advanced USB 3.0 Mini-ITX Desktop Chassis ... R 534.00 Incl. VAT
with standard 350w PSU
http://www.rebeltech.co.za/index.php?main_page=product_info&cPath=30&products_id=5672
Thermaltake LitePower, 350w, ATX 12V V2.3, active PFC, dual +12v rails, 1x 6 pin .... R162
Do they say if it is a Flex ATX psu or SFX psu required.
If it takes a SFX look at the CFI 300w psu
Search code: PS-C300SFX
Apparently it is a non-standard PSU...
Not a whole lot to say about this power supply other than it is about the weirdest shaped power supply we have ever seen. Nonetheless it is specially designed for the AOpen XC Cube computer. This 275 watt power supply has part number FSP275-60CU and will fit perfectly in all of the AOpen computer systems and part numbers listed.
http://www.atxpowersupplies.com/275-watt-power-supply-FSP275-60CU.php
http://www.supernotebook.com/power-supply.php?psupart=458419
The power supply, as you can see from the internal photos and images above, is NOT an ATX design. It's smaller in every way, maybe a little bigger than 1/3 the size of standard ATX PSU. It is a custom size that does not fit any standard form factor, as far as I can tell. It does use an 80mm fan whose speed is thermally controlled.
http://www.silentpcreview.com/article140-page3.html
Thanks for the reply fellas. Ive decided to build it into a new box. Would have been cool if the Xcube could have been retained.
