While not being able to hear sirens or hooters.
Great idea...
So normal behaviour from people generally?
Great idea...
You can get a 4 gauge kit for under R300 at Makro, R699 for 8 gauge is a bit much :wtf:
CorrectAmp and speakers should work together however the sub you've chosen looks like DVC.
They either come in dual 2 ohm or dual 4 ohm options which affects the wiring options and final impedance. The amp can essentially only run on variations of 2 ohm or 4 ohm. Wire it at 1 ohm and the amp will struggle and probably damage itself and the sub.
You're going to need a dual 2 ohm wired in series to create 4 ohms on the two bridged sub channel.
Also the bridged sub channel is 125w RMS which may be a bit light for the sub you've chosen. It's max input power is 300w RMS. Amp power and sub power should be matched or thereabouts as a rule of thumb. However the RE sub mentioned above still plays well underpowered. I haven't seen many Kicker installs so I'm not really sure.
Correct
http://www.kicker.com/app/manuals/amplifiers/dx/2014_DXA_4_Channel_Amps_RevA.pdf
http://www.kicker.com/app/manuals/subwoofers/CompD/2013_CompD_Rev_C.pdf
I just read over everything to get an understanding, I'm leaving the actual install to someone who knows what they're doing.
Call your friend that knows about this and run it by him. It gets complicated especially when you buy the wrong thing.
Yup ran it past him and the installer.
Edit : Nice job you did, here is what I would have done.
Depending on what model it is (LT or LS) it will either have 4 speakers or only 2 in front. Either way the wiring will be there to fit speakers in the back if you have the 2 speaker model. With a bit of luck you might be able to fit 5.25" speakers in the rear speakers pods - but I cannot guarantee this.
A few years ago I went through the same exercise on a Corsa Lite. I only used the designated speaker mounts and upgraded from two 5.25" speakers in front to 3-way 6.5" in front and 2-way 5.25" in the back - massive improvement.
Seeing as you want to keep the factory fitted head unit I would get the best 4" speakers possible for the front. The rear pods take a weird sized 4x6" speaker but if you use universal mounting strips you should be able to fit some 5.25" speakers. So I would get me some of these :
Front - http://www.takealot.com/sony-xs-fb1030-220w-4-speakers/PLID36958138
Rear - http://www.takealot.com/sony-xs-gt1338-5-25-230w-speaker/PLID34156004
Fitting rear speakers - http://www.ngrcomputers.co.za/5-Pac...o-Door-Lock-Secure-Bracket-ap-B00JJ56TF2.html
If you are not planning on fitting it yourself then buy the speakers and take it to a place that does car audio, they will have everything you need to fit the rear speakers and do it for a reasonable price.
Glad you sorted it out nicely like that. I once did a day trip from Johannesburg to Cape Town in a Spark and the only thing I did not like was the stock speakers : http://mybroadband.co.za/vb/showthread.php/526172-Johannesburg-to-Cape-Town-in-a-city-car
So an update.
The 4" speakers just slot into the dash, I have them powered via the deck as it provided enough power.
10" DVC in a slim box, the box cost me R450. It performs awesomely without annoying anyone, so nobody's windows rattle lol. The amp still needs to be mounted.
Nice and clean. Are you using all 4 channels to run the sub?
Nope only 2 channels. The guy who did the setup is a neighbour, when we first wired up the speakers to the deck he said it sounded fine, today he hinted about wiring them up to the amp. He's kinda of an audiophile, his system has Rockford components. He has some free time and it has turned into some kind of project for him, he's getting some LED's to shine off the perspex, so its win win lol.
