Connecting printer with Ethernet LAN cable or USB cable?
If with USB cable, then you must enable SAMBA print & file sharing on the router, it is disabled by default. I can't give you details, as I don't have this model.
If with Ethernet LAN cable, post router IP address, your IP address and printer IP ... EDIT. I see this is the case. Port is already used by your attempts to install a different driver. When running wizard create different TCP port.
