BloemGuy
Hi,
We've noticed that battery life in a few devices seems to be significantly shorter using a Telkom Mobile SIM. Tried it in an iPhone5, iPhone5s, iPhone6, iPhone6s and Samsung S4.
Using Vodacom/MTN sims, the battery life seems to be pretty standard. However, switching to the Telkom SIM the battery life is horrible, and on the iPhones hardly last a full day on standby only, whilst with the other networks they go 2-3 days.
Setting the iPhones to not connect via LTE on Telkom seems to get a little bit longer battery life, but still significantly shorter than with Vodacom and MTN.
The Samsung only has a setting for GSM or WCDMA when on Telkom, with GSM mode giving Edge connections and not increasing battery life much.
The LTE signal at home is about 3 bars, so I guess that could impact on the battery. Also, I notice when setting LTE that the iPhones warns that Telkom is yet LTE certified for the devices. Is that why they perform so poorly?
Thoughts?
Thoughts?
