I watch TV and game with Bluetooth sound (LG CX -> Sony XM3), and never have a delay. Even the slightest lipsync is usually pretty obvious and annoying, so not sure why I don't have this issueAny advice on the best bluetooth headset for TV watching? I had one previously, but there was a delay in the audio so sometimes when people were taking, there was an out-of-sync with the audio. Anyone have any advice here ?
Headset ? Unless you mean the MAX, which will cost you a kidney and an arm.Apple TV + Airpods
You can even adjust the sync.
Question is .. the OP wants a headset. Cheaper AirPods are 'in ear'. I won't go for that.AirPods. What’s the question?
Dolby Atmos and everything.
What's you budget?Any advice on the best bluetooth headset for TV watching? I had one previously, but there was a delay in the audio so sometimes when people were taking, there was an out-of-sync with the audio. Anyone have any advice here ?
We probably need to know more how the OP uses his BT.I use the Anker Q20i with my android tv box and it works well.
It goes on special for R8-900 now and then.
In my case everything goes through my Yamaha receiver which has BT (DSTV, HTPC, Media BOX). So it's just a matter of pairing my Sennheiser's to the AMP and I find no or little latency.
I went through all the posts and nowhere did the OP mentioned he/she needed Dolby AtmosBut no Dolby Atmos?
Maybe the TV has some built-in compensation
OK, I give up. They are best maybe. But the OP most likely just meant , best with connecting to his TV for latency issues.OP said best…this is the best experience you can have.
