With the good hybrio's getting harder to find it might worth my looking into those. What shops stock them?Uniross is good, its what I use.
I have heard that the Sanyo Eneloop batteries are better tho.
Eneloop is the best. I previously used Uniross but now use Eneloops. Google a bit and you will see theyare the best.
That's why I keep a couple dozen in my camera bag.I found GP better than Uniross. But a set of Hybrios is worthwhile to have because they stay charged.
+1Uniross Hybrio - 2100ma.
Uniross Hybrio - 2100ma. Make sure you get the ones that actually have 2100ma on the battery.
I'll try and find the post but they're trying to pull a fast one by claiming some of their 1900ma batteries are 2100's. The best thing about these is they come pre-charged and they hold their charge when not in use.
+1
Uniross also does a fairly large free battery recycling initiative in SA, so they get my support.
Large Pick 'n Pays. Look for man size green roundish cardboard containers /w uniross markings. They sort the batteries by type & then either recycle or dispose of them correctly.Interesting... any idea where the drop off points are?
Only one I've actually seen is in the PicknPay hypermarket on Atterbury road (PTA).
I find energizer last much longer than Uniross.
Those grey, four battery, chargers that come with the uniross batteries are possibly the worst charger you can use.What about Maha and Hahnel? I have not seen these around, but heard some good reports about them.
Must say that I have had good performance from GP and Hybrios. How important is it to use the original charger with the batteries, or will chargers do the same job?
