BILLION 400G TO MAC HELP!!!
GEE_911
Johannesburg
I have just got this router yesterday, and i dont know how to set it up :( anyone who is using it, plaese tell me your airport settings and router settings thanks...
too lazy to look up screen shots/ man on the router. But setup is straightforward.
On router go to wireless, remove any wireless security settings, set it to assign dhcp address's, select a channel number, make sure it broadcasts the ssid, change ssid to something u will recognize.
On ur mac, make sure airport is on, select the wireless network, connect.
Test connectivity by pinging etc..
then move on to changing security settingts
Hi did you connect all the cables?If you did just open your Web browser(Safari),by the address bar type 10.0.0.2. It will require you to type in the username and password. The username and password is both "admin".Then you will be logged in to the billion page.:)
