- Nov 20, 2015
As per the title.
So we started to hear an ominous, grinding noise at the left, front wheel of our Sharan. But we had the brakes checked, and according to the guy who did the inspection, they're ok.
So I removed the wheel to gain access to the brake pads. Outer pad is OK.
Inner pad is seri-assly iffy. This is due to some modifications made to the pads to make it fit.
So I ordered the correct ones from Midas (had to look them up in the brake parts catalogue) and will be picking up the (hopefully) correct ones this afternoon.
The images shown is the inner brake pad. It have a sort of clip which clips on the inside of the brake caliper piston, but it was removed because it did not fit. Because a metal piece was under part of the piston, it did not sit properly.
So, yea, brakes and modifications does not go well together.
I'm just glad we did not had a serious accident with the car with loss of brakes etc.
The disc itself is fine, whew.
