broadband on the move
scud
Cape Town, SA
I'm about to start a 3 month project that will take me all over SA, but mostly to remote areas along the coast. I need to be in email contact all of the time, and use my macbookpro to update a website daily (will be working from the car most of the time).
My plan is to use a HSDPA E272 USB Modem (possibley with an antenna) for the laptop, and a blackberry for quick email.
I would appreciate any advice or alternative thinking on this, as i really need this setup to work.
thanks
Sure that would work fine, but the only problem would be having to keep two separate subscriptions going: one for your data via the modem, and a completely different subscription for the Blackberry.
Why not forget the Blackberry, when any decent cellphone these days will also access your email (using the same SIM card as your data modem, which keeps things simple, and cheaper), the only difference being that doing it this way means you have to 'pull' the email on your phone where a Blackberry 'pushes' it - - - meaning that you physically need to check your email on your phone as often in a day as you feel necessary, rather than waiting for your Blackberry to beep. Not a great drawback, surely?
If you have the option of choosing a provider, you might also like to look at the coverage maps to see which has the best EDGE where you are going -- that's if you are going to be away a lot from the urban 3G/HSDPA signal; GPRS is quite painful on your laptop, it can be so slow, and EDGE is a definite improvement (theoretically about triple the speed of GPRS, and more stable). The consensus of this forum seems to be that MTN on average has better EDGE coverage out in the rural areas, while Voda is strong with its very high-speed transmissions in cities and (some) towns.
Don't bother with contracts unless you really have to, by the way. Not only do you get locked in, but prepaid data is actually cheaper in many instances, certainly when you buy airtime through discounters like Pick&Pay. No connection charges either -- just a couple of rand for a prepaid SIM!
You could use your BB as a modem, but obviously only on 2G, so using a 3G modem like the E272 makes a lot of sense when you're in 3G coverage. And you can get the benefit of 1Mb/s+ upload speeds.
Only thing I'd add to you setup is an external antenna from Poynting on a magnetic base, to stick on top of the car.
Cheaper than r69pm for unlimited push email and other on device usage? As far as I'm concerned that's about as close as you're going to get in SA to a genuine bargain. :o
Surely the newest blackberry's like the Bold are 3G? When is that going to be released?
Later this year. Already put my order in. ;)
thanks guys , lot to think about.
Looks like I should probably just use my old n70 as a tethered modem, and use payg data. that way i don't have to buy the E272 or start a new contract.
Although i don't have a blackbery yet, i really like the push email concept, as well as the qwerty keyboard.
I'll be ready to ditch the pearl and its quirky keyboard by then.
Careful - they didnt get the nickname Crackberry for no reason. :D
If you can, get an E272. Sounds like you'll be doing a fair amount of uploads and HSUPA will help a lot here. But check the coverage map first.
I'll have to use EDGE mostly, but that should be ok.
The vodacom coverage map shows far better EDGE coverage than MTN.
can the E272 be bought outright, (no contract)? can't seem to find it anywhere
Check your local Vodashop.
Try Greenpoint or Canalwalk.
