Calling all Javascript Experts: HELP
jan12345
Eloff
Hello to all,
First of all, thank you for taking the time to look at my problem.
I am working on a web form that uses JavaScript to dynamically insert select boxes into the form, i managed to develop a simple script that was able to do achieve this.
Basically, i want to have a select box with options that "onClick" adds a select box with two options in the "test" div using the innerHTML function.
Take a look at the code:
Code:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<title>My Problem</title>
<script type="text/javascript">
	function addInput(){
		var myValue = document.forms['test']['select_options'].value;
		if(myValue == 1){
			document.getElementById('test').innerHTML += "Option 1:<select name='option_1'><option value='1'>Yes</option><option value='0'>No</option></select><br />";
		if(myValue == 2){
			document.getElementById('test').innerHTML += "Option 2:<select name='option_2'><option value='1'>Yes</option><option value='0'>No</option></select><br />";
		if(myValue == 3){
			document.getElementById('test').innerHTML += "Option 3:<select name='option_3'><option value='1'>Yes</option><option value='0'>No</option></select><br />";
</script>
</head>
<body>
<form name="test" action="test.php" method="post">
<div id="test"></div>
<select id="select_options">
	<option value="1" onclick="addInput()">Option 1</option>
    <option value="2" onclick="addInput()">Option 2</option>
    <option value="3" onclick="addInput()">Option 3</option>
</select>
<br /><br />
<input type="submit" name="submit" value="Submit" />
</form>
</body>
</html>
As you will see when you run this on Mozilla Firefox, it works perfectly :) , however, when i try to run it in IE or Chrome it does not want to work :mad: .
I suspect it has something to do with the innerHTML function and the way it interacts differently with different browsers :confused: .
I would appreciate any help you want to throw my way.
Code:
<head>
var Options = new Array("")
Options[1] = "Option 1:<select name='option_1'><option value='1'>Yes</option><option value='0'>No</option></select><br />";
Options[2] = "Option 2:<select name='option_2'><option value='1'>Yes</option><option value='0'>No</option></select><br />";
Options[3] = "Option 3:<select name='option_3'><option value='1'>Yes</option><option value='0'>No</option></select><br />";
	function addInput(v){
		document.getElementById('test').innerHTML += Options[v];
</script>
</head>
<body>
<div id="test"> </div>
<select id="select_options" onChange="addInput(this.value);">
	<option value="1">Option 1</option>
    <option value="2">Option 2</option>
    <option value="3">Option 3</option>
</select>
<br /><br />
</form>
</body>
</html>
I moved the fx call to the <select event
I dropped the appended HTML into an array to eliminate that action being an issue
I then tested and it works...
Like this:
Code:
<head>
	function addInput(myValue){
		if(myValue == 1){
		if(myValue == 2){
		if(myValue == 3){
</script>
</head>
<body>
<select id="select_options" onchange="addInput(this.value);">
</select>
<br /><br />
</form>
</body>
</html>
EDIT: Haven't tested it yet, but it should work, will look at it at home if it doesn't.
Like this:
This. And if performance isn't critical, consider using jquery. It separates js from markup and speeds up your dev time.
Wow, thank you guy's. i will definitely look at each of these solutions and get back to you.
Thanks a milion
