Car Sound Help xD
Do you have an amp to drive the splits?
Here is my thoughts and many will disagree, but I am still going to give my 2c.
Use the Dixon head unit and buy those kicker splits. It's better than having nothing in your car.
Buy a 4 gauge cabling kit, decent one.
Buy a decent 4channel amplifier. Install amp and wire kicker splits to amp.
Buy a decent head unit and replace the Dixon.
Buy the sub you want with a box and connect to amp.
This can be done as you have money for the components. If you can, give an amount you want to spend on each and we will post, what we think, the best component is you can get for that amount.
Nothing to disagree with, that's solid advice. Obviously don't get everything at once, but as your budget allows for it.
he didn't say anything about the future now did he? you just made that up all by yourself, and you forget I mentioned that he could buy an amp to run the 6*9s, so he can just fit cheaper splits infront if he wanted too
all within that R1500 budget for that splits in the link
Sure, like how you made up the fact that your advice was based on a R2k budget which was posted after the fact.
Splits is not something that you want to go cheap on, it's something you want to go proper on.
Get a life, admit when you were in the wrong, and move on. Your penis size doesn't matter online...
wrong? the guy found a headunit in his cupboard and thought he use it, so now your advice is for him to go big on sound?
forgive me for trying to be budget conscious, I'll watch you give out your expert opinion, please go ahead and lets see what sound you come up with a 2k budget
wow... a 2k budget and these people are bitching and moaning with one another... Does it really matter in your lives at the end of the day???
Relax guys. Nothing to get excited about.
Awesome thanks for the advice!
Ill get those kickers and install the headunit, ill get the audio shop to install padding and stuff in the doors aswell to make sure theres min vibrations, and ill take it from there, sub will be my last thing, even though it makes the biggest difference, im aiming for good quality door speakers 1st
its just for my door speakers and installation i dont think its bad xD
Nobody is bitching. But when saturnz enters a thread, you can expect some k4k to inflate his ego further down the line...
i dont see spending an extra R1k on another headunit will make that noticable difference.. like maybe a small amount but i can use that extra cash for contributions towards amp or something, dixon will bwe fine for now
you were the one with the insult first, did I call anybody a n00b or make it personal, this is simply you, try next time
Listen here I'll moer the both of you guys ok? at the same time. stopit!!!
I can take you both on at the same time with that Zangief spin thing. So please, stop going on.
so if I don't stop responding, you going to do what exactly?
amazing how I contribute my views to a thread, someone insults me, I respond, and now you threaten me with violence
this all makes sense to you
jasis this guy... you obviously can't see through my k@k praat hey? I'm joking FFS.
This thread should've been closed already but I see that you are the one that wants to continue bickering over k@k.
people don't see through my jokes, so why should I see through yours?
you derail the thread but I'm the one that wants to continue bickering
want to try again?
This can get very expensive. I have looked at it before and could never justify the costs, but if you can afford it, it is a must. My last decent install was in my Fiesta ST and I used lightning audio and rockford products. Wanted to do the sound deadening as well, but never did. If you can do it yourself, it can be a lot cheaper, but it's a lot of work and is time consuming.
