Mystic Twilight
So I have a Ford Fiesta 2010 model (same model type that came out in 2007/8). More often than not when turning the ignition the car makes that starting noise but there is no ignition, just like your typical Hollywood cliche ignition problems in a horror movie. When I turn the key back and try again, I don't get the ignition noise but instead get a rapid repetitive low pitch clicking like noise and the needles on the instrument cluster move up and down very rapidly in millimeters. At this stage I have to either use jumper cables or push start the car to get it running. If I use any electronics(radio, headlights) before attempting to start the car the above scenario occurs except the car is guaranteed to not start, but there is no obvious indication that the battery is drained such as dimmer than usual headlights.
Obviously a mechanic would know what is wrong, but if someone can give me a few pointers then perhaps I can solve the issue myself. It sounds like the battery needs replacing but the lack of dim high beams or a flat battery makes me think otherwise.
Advice is much appreciated.
