Hi all.
My Fibre link speed is all over the place. I am with Openserve and used to be with MWEB on the ISP side but after they could not solve the problem I decided to move and also find a better deal. I went to WebAfrica as they had the best deal on Openserve. At first all worked fine. But now I get the same issues so I suspect that it is Telkom that is the problem. I have had Telkom here 2 time and they tested the fibre link and it shows all OK. but as soon as the drive off it starts again.
My speed will be 100 mb/s one moment and then drop down to 4 mb/s. It is not my network as I tested it with a broadband connection between a PC and the OTN and I see the same thing there. I also run a Mikrotic router where I can see all the links and when I do a speed test I can see that the PPPoE link will go to what ever I see on the speedtest side. So it is not another machine on my network hogging the line.
So now I want to graph my speed over time. I found http://testmy.net/ that will do it but they dont have local servers so I dont get the speeds they I get to a local server. I want to see when it is that my speed drops to see if I can find a pattern.
Thanks all.
Thanks all.
