Cheapest Cell C 3G Wifi Device
Superhero
Bryanston
I don't have a speedstick or anything at the moment and need to find a "not so expensive" device that will share my cell c 3G with someone in the office. I've looked at 3G wifi routers, but then I must buy the router and a speedstick. Do you know of any reasonably priced devices that will be able to do this - I dont wanna spend more than R500 (or am I crazy to think I can get away for that price!!!).
I don't want to plug a speedstick into my laptop USB and then create a wifi hotspot as the other person must still be able to work when I leave the office.
Thanks Richard - only problem is, you still need a speedstick (USB 3G stick) - and isn't it like another R500 for a speedstick, then you're already looking at R1000?
Yes, correct but you can shop around for speed sticks bought my CELL C 3GIG and stick for R399, not sure if CNA still have them on promotion or you can get the giga 200 with dongle for R1999 at CNA. If they still have stock.
I will be getting the wifi router goody from 8ta - costs R1000 - huawei e5331 router
details
-21mbps
-connect up to 8 devices
-slim design - 12.8mm
-battery 1500mAh - 5hrs surfing
Check Web pages for Vodafone R20x Mifi router with modem and battery. I have seen 7.2Mbps model around R350 from reputable dealer.
Buy a second hand phone that can make a wifi hostpot. Samsung Galaxy Pocket is a good option.
