Hi all,
I am a very new kubuntu hardy user (decided to install and give it a go) am using the 32 bit with nvidia card on the restricted drivers.
k,well got compiz installed and working but its causing a few troubles when enabled and all the effects work.
Now when I have my mouse on the front window the other windows' behind borders disappear (im guessing this is an option somewhere). But sometimes when I go back to the back windows ,the border for the front window will like half disappear and leave lines there.
Also when I select a checkbox or radiobutton, it doesn't check them but just greys the block out.
And lastly, the icons that "bounce" on the cursor when you run something don't draw properly, they'll have like a black background to them or something.
Ya I'm a complete linux noob so I have no idea how to fix this or even what to search for in google so any help appreciated
Thanx in advance
S1ght
*EDIT managed to fix the windows bar thing
Thanx in advance
S1ght
