I'm looking to build a basic HTPC (nothing fancy). I require the following components:
1 x Cooler Master Elite 100 Chassis (CH-CE100)
1 x Power cable (if not included with the chassis)
1 x Intel DG41TY "Classic Series" "Trinity Valley" Socket LGA775 Motherboard
1 x Intel Core 2 Duo E7400 2.8Ghz CPU
1 x Seagate Momentus 7200.3 320GB SATA 16MB Cache HDD
1 x Transcend JetRam High-Performance 2GB DDR2-800
1 x SATA cable
1 x D-Link Wireless N 150 PCI Adapter (DWA525)
1 x Logitech DiNovo Mini input device
If you can offer alternative components up to the same spec that will be fine as well.
Thanks in advance.
1 x SATA cable
Thanks in advance.
