Connecting 2 Edimax Wireless Routers
ggoosen
HI Guys
I just bought 2 routers... 1 is a Wireless ADSL(AR7265WNA) router in AP mode.
And the other is a Wireless ROuter(BR6226NL) setup in AP Bridge Mode-Single Point or (Station infrastucture mode)
I have to parts 2 the network the part (A) which has 2 pc's on and connects via ethernet to the ADSL router.
And part (B) which has my laptop , XBOX and Edimax Media streamer on Which all connect to the ether net ports on the BR6226NL router.
I want to be able to connect Part A's pc's to part B's pc.. so my thinking was that i woudl connect the 2 ROuters via wireless to each other..
I though that this could be done with AP-Bridge..
BUt alas.. i am not getting it right..
Both routers have DHCP so
Part A's IP range is 192.168.2.100-192.168.2.200
PArt B's IP range is 192.168.2.10 - 192.168.2-20
When connecting items to the routers they are correctly served with ip addrress's
Part A has
192.168.2.1(router)
192.168.2.101(pc1)
192.168.2.102(pc2)
Part B has
192.168.2.10(router)
192.168.2.11(Laptop 1)
192.168.2.12(XBox)
However I cannot from any pc in part A see any Pc in PArt B
If i try and ping from any pc in either network to any pc in the other network part i get no resolution
Also as Part is the ADSL network i can get onto the net from there
However from Part b i cannot get onto the net
that tells me that part B is not connected to Part A
Please help.
The only way so far that i have had my XBOX seeing the net via part a
is if i connect my laptop to part A via wireless
then connect my xbox to my laptop via ethernet.
then bridge the 2 connections.
