Hi,
My CPU is currently running quite a bit hotter than I would like (Stock i7 920) and I'm thinking about purchasing an aftermarket cooler to reduce my CPU temps a bit, I don't want to spend to much and probably won't overclock but if it leaves temps for me to do so I would be happy. Its currently idling at 50 something and goes past 80 in prime95 at stock. Which budget cooler would you guys recommend at around R300? Using a CM690 case and was looking at this cooler:
http://www.takealot.com/electronics...212-plus-rr-b10-212p-gp-aluminum-base,4949351
or this
http://www.takealot.com/electronics...-performance-cpu-cooler-for-intel-and,9359962
Any feedback would be great, thanks.
or this
