c3n0byt3
Hey folks,
Been having this issue recently, and need some speculating.
Also posted on another car forum, but no reply yet.
My AE111 160iGLE went for a normal service and the PCV valve was also replaced.
Also some sort of engine flush was done (note this was not a coolant flush).
I get home and coolant is overflowing from the reservoir tank. Happens for a short while, then the level goes down (obviously now lower than before).
Coolant is not boiling.
I've been trying to figure out what's going on.
The temp gauge sits normal throughout a daily drive (45km+45km, 90% highway).
Overflow generally happens in the afternoon when I get home and park.
The fan does not come on, and the coolant starts overflowing.
I can force the fan on (unplug the coolant fan switch), and that helps bring the level down.
Driving with aircon on and heater also helps since it also forces the fan on (well not the heater).
The fan did switch on automatically once, the other morning when I got to work, but it didn't stay on long enough to prevent overflow.
It was a pretty hot morning too I guess.
Both the coolant inlet and outlet pipe are hot to the touch.
I'm leaning towards the coolant fan switch, but my mech thinks it's a blocked radiator.
The radiator is less than a year old (replaced together with headgasket).
I've been reading anything I can find, and it could be the fan switch.
Some say air in system, but for over a month?
Some even say electrical issues with grounding, stopping the fan coming on at the right time.
And yes some say blocked radiator.
I guess it could go either way.
Fan helps stop the overflow.
But temp gauge and the fact that the fan actually can come on could mean that the coolant temperatures are fine, but the radiator cannot cope with normal expansion due to some blockage. Basically the blockage is eliminating one of the cores, resulting in smaller overall volume.
One thing I also noticed is that the radiator cap is 1.1bar.
I think the oem is 0.9bar.
Could this be causing the problem?
