hi guys,
I am having a weird issue with my machine, that I am hoping someone can shed some light on.
I have had the PC running perfectly for years until a week or so ago, when I noticed my fans spinning up suddenly. After investigating I figured out that something was up with my windows install, as Servicehost was using 25% CPU at idle.
I reinstalled Windows, thinking that this would solve the issues. While installing I noticed the fans consistently spinning up, to combat temperatures.
After the reinstall I started up HWMonitor, and was shocked to see my CPU temps reaching 90+ under load. The machine has also intermittently been shutting down to protect the CPU from overheating.
The machine specs are as follows:
i5 2500k @ stock
Corsair H60 Closed Loop water cooler
I have remounted the water block with fresh Artic Silver 5, cleaned the radiator out, and made sure all the fans were operational.
The pump and fan speeds are absolutely in order, with both the BIOS and HWMonitor reporting speeds of ~4000rpm and ~1200rpm respectively.
I am running out of ideas of what to try.
Has anyone had experience with the H60 breaking/stopping cooling, etc?
Cheers,
Michael
i5 2500k @ stock
Cheers,
Michael
