Sn00zE
Hi guys,
I decided to go for a full wireless N range setup at home and got the following D-Link devices:
D-link DSL-2760U rangebooster N ADSLmodem
D-Link DAP-1360 Wireless N Range Extender
The DSL-2760U ADSLmodem router work like a bomb! Excellent piece of hardware! My adsl has never been this fast and working 100%..
My issue is with the DAP-1360 Range extender.. I connected the device and used the setup wizard to set it to repeater mode and is working until you connect something to it!! My laptop and 2 others(one laptop is N enabled) and my phone(also N enabled) will stay connected for about 2min's +- then the connection gets dropped and throughput is very slow! Sometimes after it has been dropped the connection just never returns and it keeps on trying to connect until i reset the AP. It does not matter if one device or all is connected, all connections gets dropped after a few minutes...
My DAP-1360 is Hardware: 1A, Firmware 1.01. There is no update available on the firmware..
On the D-Link forums i found numerous complaints about this device and dropped connections and some that got it working..
I spent hours resetting the device and trying all the different configs i could get, only using b+g only using g, manual settings, wizard settings.. And so on.. But to no avail will it work properly when in repeater mode..
For the last week or so i had the AP set to access point mode with a different SSID and so far so good but its not the way i want it to work.. Some recommend RMA to get the B1 hardware version with Firmware 2.xx.
Does anyone have the DAP-1360 setup in repeater mode and work 100%?! Please save your config and upload it for me!?! PLEASE!
Anyone else got an idea i can try to get it working in repeater mode!?
Also how do i setup my wifi to move from one AP to the next AP without losing connection or manually reconnecting to the closest AP, cant seem to find any info on how to set this up on the D-Link devices i have..??
