DB9 - DB9 console cable?
Pitbull
Verboten
Hartbeespoort
Sorry to have to ask this but I'm pretty confused now :o
The switch I bough seems to work on a different console cable to the one I am using for the Cisco routers :confused:
The Router cable is a DB9 - RJ45. DB9(PC) - RJ45(Router)
Now the Switch seems to use a DB9(Switch) - DB9(PC)
Is this right?
BTW: I know it should be a rollover cable :p Just incase someone tries to be smart :p But is there a rollover cable with DB9/DB9?
nvm, found the answer:
http://forums.linksysbycisco.com/linksys/board/message?board.id=Switches&message.id=1105
Hi,
I had the same problem until now. Fortunatelly I'we found somewhere the original cable and I was able to communicate with the switch. Finally I pick up my multimeter and checked the cable itself. The cable is not a null modem cable or a full serial cable. It is a straigth DB9F - DB9F cable, so the pin assignment the following:
1 - 1
2 - 2
3 - 3
4 - 4
5 - 5
6 - 6
7 - 7
8 - 8
9 - 9
G - G
Zoltan
Message Edited by SUF on 07-05-2007 04:22 AM
This is just stupid, but will have to go buy one I guess ....
