DC to Micro USB cable
YeLo
Hi all. I recently bought a Mini UPS for my WiFi router. However, the UPS came with a DC output cable and my router's power input is via Micro USB.
Where can I buy a DC to Micro USB cable or a DC to Micro USB adapter?
I've searched Takealot to no success.
what does the output cable look like and is it 5 or 9.or 12 volts output
I'm not sure about the voltage. The cable came standard with the UPS and the UPS can be configured to output either of the 3 voltages.
go get a female cctv socket R15 and a usb cable for the modem .cut off the big plug and fit the 2 power wires into the cctv plug and off you go + and - are marked .or just go too your local cctv shop im sure they will help you .even local computer shop.you can also get the male which would do away with the supplied cable .
Screenshot_20221004-221330.pngthose prices are ridiculous though .local china shop .matrix .cctv shop .builders .just check the plug sizes are the same diameters
