Difference between E7500 & E7600 cpu's
marco79
Back in CPT!
Would there be a great difference between these two processors? I am building a new PC and cannot decide which to go for the E7500 2.93Ghz or E7600 3.06Ghz. The price difference is about R300. My current PC is a P4 3.0Ghz.
I will be using the PC as a media centre, using my 42" plasma tv as its permanent monitor. I don't play games at all on the PC. I will also get either a HD4650 512Mb or HD4670 1Gb graphics card with the cpu. I already have 2x 2Gb DDRII 800Mhz memory.
Go for the cheaper one, you will not notice a difference between the two....
the only diff is the multipler.... but the ceaper the processor the better... lots of ram is nice if you gonna use media broweser
well, the fact that the E7600 has a higher multiplier means that you can overclock it a lot higher. But unless you wanna go ape with overclocking, the E7500 is ideal :p
The Celeron on Pentium are more than fast enough. Both are much faster than your P4
