Does anybody know what the actual differences are? The only ones i could spot is the jamin has a better camera and its got mobile office. What i dont understand is why the kjam is more expensive?
The K-Jam is a bit finicky ... Any BT GPS will work on your device ... I used to use the Adapt AD 750 ... Sirf Star III device .. very affordable with great performance ...
After pairing your GPS receiver you need to create a serial port and a outgoing COM port ... deselect the Secure connection option ... with this option checked the GPS receiver will not reconnect to your Device ...
I use Handymap Ai gold ...
entry Level Handymap Ai Standard and a GPS reciever = R 2099.00
Handymap Ai Gold with reciever = R 2899.00
For the K-Jam 2 Gig Mini SD cards are available ... The Jammin uses normal SD cards which are up to 4 Gigs ... apparently 12 or 16 Gig cards are in production
I am not sure if the data bus on the devices will support it though ..
Get this app..... http://www.freewareppc.com/utilities/tman.shtml its a task manager for ppc. No more going to the memory util to close apps. You can also select an app from the list when you click on the taskamn icon.
