Dlink router wireless setup!Help
ViciousClone
Western Cape
Hi all
Ok well i have two of Telkom's D-link routers..one is setupd on my main pc..and i need the other one for wireless setup for the rest of my house..
Problem is..i already inserted the wireless settings on the 2nd router and placed it where it picks up the main router..
OK so now i get full singnal when near it..but no internet acces?...
Hi all
Can someone please tell me how to bridge?aparently that would let the two routers share connection..
OK last thing i can say is ..
2 routers ..identical..
one is connected dsl/pc(main)
the other router(second) is in the other side of my house which i would like to be a repeater..if possible
I dont want to connect them via cable..
thnx
If you'd like to use it as a repeater, then setup both to use WDS.
Please just take note that WDS is brand-specific, so do not try to use WDS across different brands. Luckily you have the same model.
So they can be a reapeter..Greate!!
Can you please explain how i do it?
Model is a D-link dsl-2750U router from telkom..
You can read up on page 89 of the user manual: ftp://ftp.dlink-me.com/DLink_ME/ADSL/DSL-2750U/DSL-2750U_Manual_ME_1.00_20110302.pdf
I haven't configured WDS on a D-Link router/modem before, so I can't tell you for sure how to do it.
My guess would be:
On the ADSL side:
AP Mode = Access Point
Bridge Restrict: Disabled
On the other side:
AP Mode = Wireless Bridge
Once you have it working, you can enable (scan) bridge restricting on both.
