I have looked for the such a thing but can't find it. I have tried to convert some routers to wifi switches (disable DHCP and give the extender a static IP outside of the DHCP range), but with power failures and load shedding, they revert back to default configuration and arent so reliable.
What I would like is something like this: I have my router ----> long ethernet cable ---> Wifi switch.
The wifi switch communicates with the router via ethernet cable, but it talks to devices near it via wifi, allowing areas far away from the router to have wifi.Basically extending the wifi.
I am not looking for a unreliable wireless wifi extender. It must connect to the router via ethernet.
I would like a dedicated product. Setting up routers to do this has just proven to be a constant source of pain for me.
Does such a thing exist? Bonus if I can make it use the same SSID (so the wifi appears seemless), and bonus if the wifi switch has some ethernet ports one can plug into too.
My router is a D-Link DIR-825 if that makes any difference.
