Download speeds dropping to zero with Mweb - please help
Nightling
Hi, I've been experiencing really bad download speeds during the past couple of months. I am on a 1mb line with Mweb.
Whenever I'm trying to download any file (docs, pdfs, exes), the download rate randomly falls to zero and proceeds at download speeds of order bytes per second (i.e. less than 1 kB/s). The download speed may suddenly pick back up randomly but usually doesn't. I have started using a download accelerator with which I get the normal speeds of about 70 kB/s.
However, whenever I can't use a download accelerator (e.g. android system updates on my phone), I am stuck with those horrible speeds.
The problem is present regardless of the device (laptop or phone) or whether I use an ethernet cable or wifi.
Please can someone help me?
Here's my tracert to bbc.co.uk:
Code:
Tracing route to www.bbc.co.za [216.8.179.23]
over a maximum of 30 hops:
  1     2 ms     1 ms     1 ms  192.168.1.1
  2    14 ms    13 ms    13 ms  41-132-48-1.dsl.mweb.co.za [41.132.48.1]
  3    14 ms    13 ms    14 ms  197-84-96-210.cpt.mweb.co.za [197.84.96.210]
  4    13 ms    13 ms    13 ms  197-84-2-2.cpt.mweb.co.za [197.84.2.2]
  5   163 ms   163 ms   163 ms  197-84-5-226.cpt.mweb.co.za [197.84.5.226]
  6   163 ms   159 ms   161 ms  197-84-4-195.cpt.mweb.co.za [197.84.4.195]
  7   166 ms   161 ms   159 ms  176.67.177.235
  8   196 ms   195 ms   196 ms  176.67.177.149
  9     *      160 ms   169 ms  40gigabitethernet1-1.core1.lon1.he.net [195.66.224.21]
 10   233 ms   230 ms   231 ms  10gigabitethernet10-4.core1.nyc4.he.net [72.52.92.241]
 11   238 ms   252 ms   242 ms  10gigabitethernet1-2.core1.tor1.he.net [184.105.222.18]
 12   298 ms   273 ms   278 ms  managed-network-systems-inc.10gigabitethernet3-1.core1.tor1.he.net[209.51.163.38]
 13   244 ms   247 ms   241 ms  ndcolo-gw.wndson17.mnsi.net [216.8.136.66]
 14   245 ms   244 ms   243 ms  ptr-216-8-179-23.ptr.nextdimensioninc.com [216.8.179.23]
Trace complete.
Have you not heard? MWEB doesn't allow you to download it anymore, they just throttle you based on usage. Sounds like you were over their 10GB a month threshold you naughty boy!
Real Help Section: Grab a trial account from Openweb, Axxess or Afrihost and see if the problem repeats using one of those accounts. If it doesn't do the same, ditch MWEB like everybody else is doing. If you get the same problem, there may be a fault on the line but your traceroute looks normal. Alternatively, check and make sure that your firewall (if you are running one) isn't interfering. Try download a file, check that it is doing a 0KB/s problem then disable your firewall and try again
Good luck!
Lol, I usually average 40-50 gigs monthly and I've only dowloaded 12 gigs since the start of this month. I've already tried disabling and even uninstalling all firewalls. That does not seem to be the issue.
Oh well, I've been with mweb for three years now; if the mweb guys can't help I shall seriously consider switching to Afrihost.
PM MwEBGUY. You will receive the standard reply's
Send me your details. Do speedtests to International and local
From the results it seems like congestion. Contact Telkom to resolve your issue
From 1 September:
You've been a bad boy. You overstepped our AUP
Regards
Code:
Trace complete.
Good Evening,
Please provide me your MWEB account details via private message and I will try and assist you.
Also note that if you did not receive any emails pertaining to usage and enforcing the AUP, you are still within acceptable parameters. The change will also only take effect 1st September.
Good Evening,
Just sent off my cancellation form. I have about 10 devices connected to my router, even without torrents etc, it's almost impossible to use less than 100GB pm.
Just an update. The Mweb people managed to fix the problem. Getting pretty constant download speeds of 100 kBps for now. Hope it lasts.
I [-]don't think[/-] know that being within or outside of "acceptable parameters" does not warrant[-]s[/-] a user being unable to open any documents/files, so mentioning this is completely irrelevant.
