Dropbox issue
tcofran
Pretoria
I used to access the internet at work through a proxy via cable. Yesterday i was moved to a wifi connection, that is much faster. I was told to disable the proxy in internet options.
Everything works fine, except dropbox, which gets blanked out in the system tray, and does not sync or connect
I've tried to change the settings here
but no luck
Any ideas will be appreciated
T
Try setting it to "No Proxy" if you dont need a proxy anymore to access internet
Will it be allowed, if you do find a way? You mentioned they did it do remove the proxy option.
Yes, Dropbox is allowed to be used....
strange shy it cant connect without the proxy ??
