DSL not working
charlieharper
South Coast, KZN
Hi.
Something is really wrong with my ADSL Modem (Telkom/Billion 5102G) or My Computer.
The Modem Sync the DSL signal, but it doesnt want to connect to the ISP (TelkomInternet) via PPPOE. But I cannot access the modem (10.0.0.2) either to check the Username and password.
Another thing I noticed, on the taskbar (i'm running on Vista), under Currently Connected To, it says Unidentified Netword, instead of Local Area Network like it used to.
Any idea what might be wrong?
Thanks in advance.
For some reason the ip changed from 10.0.0.2 to 192.xxx.1.2x4. Then I managed to get into my router. But it still dont want to connect to the ISP. I'm going to try bridge now.
9 times out of ten this is just vista throwing a hissy fit. Have you tried resarting both the pc and the router?
Have you tried resetting the router Ronald911? That should default everything and allow you to set up again from scratch.
