Hi,
Hope someone can answer this one.
Is the cable used from the DSTV dish to the decoder the same as the type used to connect a TV to a normal antenna?
Reason: Tenants in our flat no longer wants DSTV and I must now connect the normal antenna. Will be easier if I can use the existing cable. To my knowledge I must just change the connector on the TV side...
