DSTV Freezing
ichigo
Anyone know why my dstv freezes sometimes and have to reset the decoder happens with any decoder? Also anyone experiencing the same problem?
thisgeek
I used to get that with my old dsd660 decoder. Never had a problem since I replaced it with a new one.
Imoe
If your DSTV is freezing, maybe you should try wrapping it in a blanky.....hahahaha
Just kidding, I replaced my Decoder to the 1110 and realigned dish. Problem resolved.
ichigo
i'm using dsd990 but probably does need the dish to be removed since one of our big trees might be blocking it sometimes :p
btw does the dish need to be cleaned?
Sackboy
I've heard it happens with the new one 110(?). They have the latest smartcard with extra security and I think the decryption isn't working well hence the freezing.
cfvh600
my dsd990 goes into what I call "black screen" mode quite often. You can still change channels and see the info bar but the whole screen is black. The only way to correct this is to pull the power plug on the decoder and to let it rescan.
bekdik
The only way to fix DSTV is place the decoder in a fire. Then buy a book.
LazyLion
King of de Jungle
DSTV froze it's programming about five years ago... now the only thing growing is their prices.
nivek
my pvr froze and rebooted itself 3 times this morning, first time ever..
ichigo
wish they would fix it so far today no freezing doesnt seem to be everyday
Roundhouse
Yip mine too , seems it was the satelite that moved a bit , but then it was fine again.
Happens now and again , I still enjoy my Dstv.
Srack0verflow
their firmware maybe?
gary: i can imagine poision in my dinner if i go, 'okay geen meer binnelanders vir julle, want ek wil throtled uncapped en 'n 4 meg kry' ;)
Quantum Theory
Yes... The satellite in the vacuum of space at a constant speed and altitude was moved by little satellite faeries.
