Hi, can anyone help me with this:
I had my DSTV installed last week, the standard decoder. I now installed a new TV upstairs, and need to get the dstv working there as well. I'm not worried about dual view, just getting the cable there is the first step...
Do one get a splitter that will split the signal so that I can just buy another cable and plug that into the splitter, and then into my 2nd TV... Would that weekend the signal, and would I notice it?
Or should I get a dual LNB installed and take the new cable form the lnb to the 2nd tv?
